Edit the IPv6 PIM parameters for an interface to customize the IPv6 PIM configuration.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6 PIM.
  3. Select the Interfaces tab.
  4. Configure the required parameters
  5. Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
Name
Description
IfIndex
Shows the interface Index. This variable is a read-only field.
Address
Shows the IPv6 address of the PIM interface. This variable is a read-only field.
NetMask
Shows the network mask for the IPv6 address of the PIM interface. This variable is a read-only field.
Enable
Shows the configured mode of this PIM interface. sparseDense mode is valid only for PIMv1.
Mode
Shows the configured mode of this interface. The valid modes are SSM and sparse. This variable is a read-only field.
DR
Shows the router with the highest IPv6 address on a LAN designated to perform these tasks.
HelloInterval
Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default is 30 seconds.
JoinPruneInterval
Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default is 60 seconds.
OperState
Indicates the status of PIM on this interface: Up or Down.
Type
Specifies the interface type.
